Toyota L.S.D. ??
dragginmazda_86@yahoo.com's avatar
Toyota L.S.D. ??
dragginmazda86's avatar
dragginmazda86
I have a rearend out of a 1990 2wd toyota to go under my mazda and i was wondering if anyone knows if their is a company that sells a L.S.D. for this rearend or if their is a donor toyota vehicle i could remove the third member from and put in this housing and use the axles i have. maybe supra or 4wd toyota? any help would be great. thanks in advance.
TwistedMinis's avatar
TwistedMinis
Detroit Locked sells a Tru-Trac LSD for them.
dragginmazda86
hey Seth i sent you a couple IM's. i'll check out detriots website for that. thanks man.
TwistedMinis
I got your IMs, just got done replying.
I'll check with my uncle and see if he is still a dealer for Detroit Locker. If so I can probably get you one for a kickass deal if more than one is bought. And I wouldnt mind having one really. Lol.
scotto79
Auburn Gears 542030 Toyota 8 7/8"
also, check this site for anything else you might need
http://www.bearsperformance.com/
time1's avatar
time1
Fuck it, just weld the spiders gears together and have both wheels locked all the time. Then you can take the money saved on the locker and put it towards something else.
On my samurai in my profile i locked the rear end the same way.....weld it.
dragginmazda86
thanks guys for your help gives me a few options and TIME_1 thats what i was thinking as a last resort but having a V8 with almost 300 hp that would be kinda scary if i had to ever drive in the rain. also Seth i was able to see the pics what did you use for proportioning valve and booster?
TwistedMinis
I got an adjustable proportioning valve from Speedway. Same thing as the Wilwood, just cheaper and purple. Lol. You can use the stock booster. But I upgraded to a 1996 non ABS Land Cruiser master cylinder with a 1" bore for the extra stopping power. I got it dirt cheap through work brand new, otherwise I probably wouldnt have bought one.
oneup's avatar
oneup
I saw LSD and got all excited just to realize your talking about a limited slip. You could do it the hoosier way and weld the spider gears and have a true posi.
turboh22aakkord
haha you beat me to it... i swear by lincoln lockers!! (on my mud trucks that is) but yeah, detroit would be a good way to go.
