Miller 375 plasma cutter hooking up on 230 how?
bagged2200
I i got a miller 375 and im trying to hook it up on 230 but its got a green and yellow wire, white wire and a black wire i dont know what one is ground i fell kinda stuipd but dont wanna burn my plasma up thanks
jetmodifydranger
Hey dude green is typically always the ground. Black is hot and white is the neutral.
rizz0's avatar
rizz0
call the miller tech support line and they will tell you exactly how to do it
jetmodifydranger
And are you sure what voltage it is?? Most times 230v will have a red, black, green, white or something along that line. Like he just said call the tech support or an electrician.
bagged2200
the green wire got yellow on it to thats what messed me up i guess i just wait until tommrow thanks guys
hotwheelsgt's avatar
hotwheelsgt
im pretty sure the green is ground and the other 2 are hots. i dont think it maters what side the white and black wire are on as long as the ground (green) is in the rite spot.
lowridn99
you got it
rrusd's avatar
rrusd
I have the 375 also, and the green is the ground. Your gonna love how this thing cuts in the 230v mode. Slices 3/16" steel like butter. Sheetmetal gets cut like paper. Have fun with it, I know I do.
bdroppeddak's avatar
bdroppeddak
Edited: 1/7/2007 2:01:16 PM by bdroppeddak
you should have just bought a new recepticle for it since its wired for either already, then you could just flick a switch on the back and turn the prong on the plug and still run 110 if you needed to take it somewhere.......
but if you cut the plug off, white/black - hot, green ground....
bagged2200
so i need to hook the green to the L shaped blade?
s10
last post by baha +1y
