Dodge Trucks \  Does anyone make?
Does anyone make?
Dodge Trucks Make Specific
views 231
replies 7
following 6
JoshC224   +1y
A 2/4 drop kit for an '07 Dodge Ram 2500
Low_SST   +1y
yea and its dirt cheap,
go get yourself some stock 1500 springs and get a 4" shackle drop for the rear and you are done. you may need to cut just a little off the coil or heat it to make it drop to exactly 2 but its a free drop over the 2500 heavy duty coils.
toreadorxlt   +1y
dont cut your coils
JoshC224   +1y
Where can i find a 4'' shackle ?
bill brasky   +1y
Originally posted by toreadorxlt
dont cut your coils
Why not? as long as you dont go over an inch or two there is no probs.
JoshC224   +1y
i cant even find a 2" drop shackle anyone seen a set? belltech doesnt make it and im pretty sure jdm doesnt either
Loomie   +1y
This is an interesting question and one that I too have looked into. The rear can't be shackle dropped unless you want the shackle to prodrude into the bed. The rear of the 2500 is not like the rear of the 1500 there is a totally different shackle arrangement. It looks similar to a new Ford setup, but with no room to work the only way to maybe make it work it to cut into the bed to make room for the shackle, I know i tried this route already. Other rear options are to de-arch the leafs and add a helper bag set up.
On the front the easiest way to lower it is to move up the upper control arms and take 1/2 coil out of the stock springs, it will still allign and ride ok. There is NO drop kit for this truck, the front's bump stops are also very close and will need removing and some steel cutting back.
gimp5561   +1y
what motor is in your truck 5.7 hemi or cummins? if it is a diesel get a set of front coils for a 5.7 1500 truck. it will drop the front 1 3/4 or 2in, in the rear remove the over load leaf. you lose a litte cargo cap. but it will drop it,add bags on the rear and your done. i have done 1 3500 single wheel truck.
