Air Ride Suspensions \  sorry, what gauge of wire to run for compresser
Air Ride Suspensions Q & A
views 139
replies 5
following 6
blazer   +1y
what wire to fun from front of truck to back for compesser,is viair 380,is full size blazer
Hc Daytona Dragger   +1y
Edited: 1/11/2007 1:44:24 PM by Hc Daytona Dragger
If it is only gonna be used for the compressor, I would say maybee......10ga???? with a fuse
For my Jimmy I ran 4ga to a distribution block then 10ga to each one for mine, but i was running dual 480's
dragginmazda86   +1y
i always run 4 gauge from the battery to the rear of the vehicle to a solenoid.
lowridermags   +1y
well im not an expert but run the 8 gauge (long way for the power to go).
like Scott said, a single 4 gauge wire to a distribution box in the back of your blazer would let you use the power for the compresser and subs later on. im with scott on this one
bodydropped85   +1y
4 gauge to the solinoid, 10 gauge to the comp.
slammeddime   +1y
Here's a wiring diagram that should work for you.
