Help Brake issue
Help Brake issue
azhooligan
Ok guys i am lost and pissed. My 91 square body has some issues. So here it goes. Going down the freeway one day a car hit the car infront of me i hit the brakes so hard that I had flatspots on my front tires and brake light came on. Got the tires fixed light would not go off so i replaced the Hydroboost, Master cylinder and shoes and pads. Light was still on. Me and my brother bleed and bleed the brakes til finally had pedal and no light. Now a month or 2 later driving i noticed they were soft and light now comes on when i apply the brake. Any ideas?
lockone's avatar
lockone
Are any of your brake hoses/lines soft? Sometimes when you stab the pedal real hard the heat from the brakes will heat the fluid and boil it for a very short time and weaken the hoses. Therefore causing a bulge in the hose when you apply the brakes giving you a soft pedal.
azhooligan
I will check i hadent looked for that. Thanks
DK
diabolic kustoms
sounds like the prop. valve to me.
pig rig's avatar
pig rig
I kind of had the same problem but once I cleaned out the 18yrs of goo that was used for brake fluid they worked a lot better and I ended up replace'n the flex lines and that was even better
also the rubber deal in the lid of the master resivor gets pin holes and that can give you problems
jcampbell1180's avatar
jcampbell1180
Don't be such a pussy. Brakes are highly overrated.
azhooligan
Lines look good. I went to Checker and they are saying they gave me the wrong master cylinder. My should be Cast insted of plastic with the JB8 system. The one I took off was plastic?
pig rig's avatar
pig rig
thats half the problem right there
the little that I've had to deal with shucks here I've found out that their computer dosn't list the R series trucks
R series is 88 -91 2wd crew cab
azhooligan
Ok got the Cast Master Cylinder now from GM for the R3500 and installing it this weekend. Cross my fingers
