IM BODY DROPIN MY 00 SONOMA ON 20'S AND IM HAVING WIRE HARNESS ISSUES. ID RATHER NOT CUT THE WATER GUTTER OUT UNDER THE COWL. ANY OTHER PLACES TO RUN THE HARNESS W/OUT HAVING TO EXTEND A MILLION WIRES MAYBEE SOME PICS? ANY HELP WOULD BE APPRECIATED. THANKS
i moved mine up higher and it worked fine. I also moved my clutch cylinder up 3 1/2 inches right up to the cowl, i dont have any pics off hand, good luck though, IM me if you need more help.
you need to run it out the side of the cowl, then run it forward. you wont need to extend many wires if you do it right. also, below the booster can work but then its right behind your pedals and gets in the way of a lot of stuff.
