hey ppl i need two three gallon air tanks but they need to be 8 inch in diameter and no longer than 16 inchs, i have one for a mock up but i need two to put on my truck any help will be appreciated thanks..
You should build your own I usually get the round tube you need, cap it, then get some threaded slugs from a good fitting and hose supplier and weld them in pressure check and your done. Hope this helps.
Find a local truck fab shop that does industrial bodies and works on semis. My friend works at a place like that, and comes across oddball tanks all the time.
