mazda frame/ buick body?????????
hillbilly.31@ hotmail.com's avatar
2 MNY TOYS's avatar
2 MNY TOYS
Edited: 1/18/2007 11:36:58 AM by 2 MNY TOYS
i need a little help i have a 1987 x cab mazda frame and a 1971 buick skylark body. they are the same wheelbase i just need to know if it will hold up under that heavy body or not any suggestions???????
jdauer02's avatar
jdauer02
you could box the frame with plate steel to make it stronger, just make sure it straight before you do. I Dont see why it wouldn't work.
bagdb2200
Originally posted by jdauer02
you could box the frame with plate steel to make it stronger, just make sure it straight before you do. I Dont see why it wouldn't work. Mazda frames are boxed from the factory...
nryota's avatar
nryota
its just the same as all the ppl puttin honda bodies on s-10 frames, if the wheel base lines up and your down with the challange to do this i say go for it, as for the strength issue just fab up some more crossmembers and so to beef it up....
bdydrp18's avatar
bdydrp18
I GO FOR IT AND ADD PLATE AND CROSSMEMBER WERE NEEDED
2 MNY TOYS's avatar
2 MNY TOYS
alright guys i think im going to try this one out might be a while though i dont have a garage and its freakin cold outside but i appreciate the suggestions and such ill keep you posted
BK2LIFE's avatar
BK2LIFE
yes it will work. mazda frames are plenty strong
s10
last post by baha +1y
