BioMax
The reason that vehicles use shocks, is not so simple as saying "because every car has one." When a spring is resting at ride height, the shock does nothing (duh.) But once you hit a bump the spring compresses with more force then the vehicle has sitting still. So once the spring releases the stored energy, the chassis bounces past ride height and into droop (higher.) then the truck is heavier then the spring rate holding the truck up and the truck falls past ride height, storing more energy and starting this all over untill it finally settles back to it's ride height. The shock slows this whole thing down and allows it to settle right away. If you never turned a corner, I would say "whatever, it's your truck," but when cornering, it is dangerous to not run shocks. There is way too much weight transfer going on to not have any control over it.
