Im a bit curious on how I should set up my behind the axle lower bag bracket for Firestone F9000 sleeve bags. It seems like the lower bolt hole in the sleeve bag is sucked up in the bag. So should I make a tubular little piece sit up in there or what? Anybody got any pics. Thanks for any help.
tbmx86
Nobody has sleeve bags in the rear?
maniacalmini
i'm in the same spot your in. takes time to get an answer that specific on here.
TRUKBLDR
get the lower bag bracket from gravity werx or SD
maniacalmini
is it specific to the f9000?
bdroppeddak
no, but any flat bracket works fine, it wont be sucked up in there when you are driving it.....
olskoolpup
the issue me and jason are seeing is that the suggested collapsed height of the bag is 4.5". when collapsed that much, the bottom is sucked up in the bag. if it were on a flat plate, itll be kinda crushed up, and we arent sure how good that is for the bag. if there was something that was smaller than just a flat plate, the rubber would be able to sit over it, not folding it up.
anyone following?? could we be trying to over engineer this? any pics of f9000 sleeves installed?
