2.0 in 2200
2.0 in 2200
mazda90b2200
i just put a 2.0 in my 2200 and the oil pan is sitting on the center link of my steering. i was wanting to know if anybodys ran in to that problem before and what they did.
orangemazdab2000's avatar
orangemazdab2000
The oil pan shouldn't be that close to the steering. Is the 2.0 a Japanese replacement with some goofy oil pan from some other application? I was thinking that if you put your engine mounts on wrong, the pan would hit the crossmember before the steering. People on here lower the engines all the time to clear the hoods with body drops.
dragginmazda86's avatar
dragginmazda86
i put a japanese replacement in my mazda and the oil pan was way off i just swapped it with my old one.
mazda90b2200
yea it is a japanese replacement. i had the motor mounts from that motor on first and the oil pan still hit then i switched to my motor mounts and it still hit. i was thinking about changing the oil pan but they look the same except the dain plug is in a different spot
wht01ranger's avatar
wht01ranger
Edited: 1/23/2007 7:02:26 AM by aftershock
Edited: 1/23/2007 7:01:50 AM by aftershock
Hmm. You sure it's a 2.0?
It should be a direct bolt-in. Put the oil pan from your 2.2 to the 2.0. It should bolt right up.
Oh yea, make sure it's not on there backwards :LOL:
