strut rods on bodydrop??
slamedb22
wut do i do wit strut rod on my mazda wen i bodydropp it??? and also were is a good spot too cut floors out so i can keep my stock heat and all
BK2LIFE's avatar
BK2LIFE
i left mine there. or you can build new ones to the rear of the control arm.
make a new frame section from firewall back and dont cut your floor, just raise the trans tunnel
TwistedMinis's avatar
TwistedMinis
I triangulated my lowers to eliminate the strut rods.
And look in the suspension section, theres a sticky on bodydropping and channelling. It shows where to cut, and help retain stock heat and defrost.
dssur's avatar
dssur
on a mazda you just drop the cab mount "ears" and notch the crossmember for the lower radiator hose. You dont have to do anything with the strut rods.
slamedb22
if i jus drop the cab mount earsand notch the crossmember how will my bumper drop down???dnt they whole crossmember have too be lowered?....and another thing will i clear the stock hood wit a 2'1/2 bd?
thatsmydawg's avatar
thatsmydawg
keeping stock heat and ac hahaha never herd of that before
slamedb22
wut u mean keepin stock heat?...wut all u guys rollin around wit out heat and all
TukinRange
both my trucks are bodydropped, neither of my trucks have heat =( or wipers or a/c. all they do is Get Down.
rwloper
you can get an aftermarket heater to fit behind your firewall from summit or jegs for like 150 bucks
dssur's avatar
dssur
on a mazda:
you can drop just the ears. You dont have to drop the crossmember unless you really want to. Mark where the lower rad hose is on the crossmember and notch it, like a c notch, or a square notch.
Dropping the ears is about a thousand times easier than dropping the whole thing, welding around the steering box when you drop the whole thing just sucks nuts. You can do the ears and the crossmember notch in about an hour. You also have to drop the bumper mounts, but luckily they are almost 3 inches tall, so whack em off and make em almost flat.
You can keep heat and ac on a rocker laying traditional bd, you can cut low behind the pedals and then go up over the trans. Some people "step" their bodydrop on top of the trans to keep the air distribution box stock, but I think that makes it harder later if you ever need the trans out. You can take the air distribution part of the heater vent off the distribution box and everything still fits.
