Chevy/GMC Trucks \  94-98 GMC on 94-98 Chevy grille swap
views 3299
replies 11
following 7
Stock Sucks   +1y
I want to change my tahoe to a GMC grille, i keep finding conversion kits for an 88-93 swap to newer 94-98 style, but i cant find anything on chevy to GMC for both being a 94-98. Any one got any ideas if they will just bolt up or will i need some brackets to relocate headlighs or parking lamps??
Stock Sucks   +1y
also are the bumper fillers any different?
JW   +1y
Everything is the same other than the corner lights are smaller on the GMC
Stock Sucks   +1y
thats what i was thinking but no one i have asked so far can confirm it....thanks
redcrew   +1y
Yeah there the same bro it will bolt right up..
bowtied   +1y
The headlights bolt up from 89 to 98 cause i did mine. And Everything converts over but i was also told the corner lights wouldn't work which i thought was wierd.
redcrew   +1y
The corner lights are taller and skinier..
Stock Sucks   +1y
thanks for the info, i knew the sidemarkers were different, and i was almost 100% sure the parking lamps and headlights mounted in the same fashion, but what i couldn't verify is that if the headlights used the same bracket to mount to the rad support, or if one of the two was a little lower than the other. I also wasn't sure if the grille had different mounts on the shell itself...although as little difference as there is in the trucks..i.e. the grille and steering wheel i would think GM would make the parking and headlights mount the same
Stock Sucks   +1y
well all i gotta do now is find a factory GMC grill and give it a try
SHOWTIME   +1y
most pcs will work.the headlights are the same.i belive the marker lamp is 1 pc just long and narrow might have to extend the marker light harness a couple of inches.the bumper braces are the same and the corner filler panels are a little differnt from old 88-93 to 94 and newer just a couple of holes in differnt places also some of the mounting holes for the grill will be in differnt locations but most will line up just fine in the older rad support but other than a couple of little things should be no big deal
