NOT LAYN ON 17s! Why?
TB
tee bagn
Ive got a 92 yota bd 4" traditional bagged front and rear fourlinked in rear jus wondering what do i have to do to drag full frame? ive got 17s on it right now but im running into a problem with the lower control are hitting the inside of the wheel if i go to a smaller size why is that? also how can i re run my wiring harnesses so they are out of my way and not rubbing tires? and ive got a problem with my clutch whatever it is how can i move tat so i can clear with 17s? bc right now its hitting like a biotch.
twistedsdime's avatar
twistedsdime
well if your body dropped 4 inches then I don't think you would be able to drag frame. Maybe body but not frame. I might be wrong though. I don't know to much about yotas. As far as your wiring harness you can just extend all of your wires and relocate it. Some people move it to inside the dash.
TB
tee bagn
thanks man for the info thatl be fun aight need some help on the other shit so common guys need to know how to move clutch cylinder up or over out of way. and why rims are hitting lower arms. thanks
Ih8bmps's avatar
Ih8bmps
The only reason I could see is you having a problem with the control arms is if your running a 3"drop lower control arms instead of spindles??? they have that problem, but with a 4" body drop, i mean thats a big body drop...Look around to see how everyone has relocated there clutch masters... I think some dudes with that body style use a smaller master out of I want to say 4x4 but not 100% sure...
slammedcivicsi's avatar
slammedcivicsi
mines recessed into the fire wall......it was a cool idea at the time 3 years ago, but now its kinda cheezy IMO. Personally Id run a smaller one, and flip it under the dash, and my wire harness rubs on the wheels too, so Im going to put trailer fenders in it. Much cleaner. I'll redo my engine harness when I work on my engine.
TB
tee bagn
thanks guys for the info i think im going to try to use a smaller wheel and then relocate this master somewhere dont know were but ill keep yall updated bout the buildup thanks agian guys post pics up lata on what i decide to do with it
