Ok i got it to start now i have to push the gas in order to keep it running because if i let go it turns off wat could be this problem and another thing what could i do to stop the smoke coming out of the exhaust its badly smoking and i dont like it so hit me up and let me know in how i can solve my problem
scrager
Did you ever check the choke. If you have to hold the gas in, then likely you need to set the choke to be on because it won't idle when the engine is cold.
as for the smoking, it depends on the color of the smoke. Blue smoke is oil, likely caused by blow by due to bad rings. The fix for that is to replace the rings, which means rebuild the engine.
If the smoke is white then it is likely water/coolant. Either this is because there is condensation in your cylinders/exhauts that is evaporating because the engine has sat for a while and is cold, or you need a new head gasket.
BB
bill brasky
^^^ he sounds right.
sounds like it just needs a tune up. Sounds like some things got changed on the build up
famzarate10
Thanks u Guys this helped a lot i got it running now
