Audio/Video \  advice: what kind of amp to use
Audio/Video Q & A
views 148
replies 4
oldskoolpimpin27   +1y
i got three 12" kicker comps in a box nothing big but what kind of amp should i use, or should i use mulitple amps
rovert   +1y
what is the impedance on the subs? I would expect 4 ohms each.
rovert   +1y
If they are 4 ohm subs, they can be wired to a 1.33 ohm load. Memphis makes a 16-PRD1000.1 (stable down to 1 ohm) which sould make 700-800 watts at that imp. and that sould be perfect power for those comps. Woofersetc.com has that amp for about $290, for a suggestion.
apreciate it
DRAGGINBODYON22S   +1y
If u can find a older ppi i would go with that the amp im thinking of is the 606 graffic seris might be hard to find but if you do it would be worth the time
