Body work and Paint \  how too seal rollpan
Body work and Paint Q & A
views 304
replies 12
following 12
slamedb22   +1y
wuts they best way too seal off and preven rust and all on backside of rollpan???
sadexcuse4s10   +1y
Edited: 2/1/2007 8:58:16 PM by sadexcuse4s10
maybe primer and spray paint the backside after you weld it on?
seems like common sense to me
mindlissmetalfab   +1y
also a good idea to hit the backside of it with some rockerguard. it'll absorb a bit of impact from road debris instead of chipping like paint will.
SHOWTIME   +1y
i put some rust paint like por or tremclad and then cover it with rock guard works like a hot dam
FreelandKustomz   +1y
epoxy primer on baresteal always
Wicked Fantacies   +1y
^ bingo! epoxy primer. then undercoating or por 15
gravity5   +1y
epoxy prime it, seam seal the edges, then undercoat it, or rockerguard it, and a final coat of rustoleum or tremclad is fine for a driver....if you want show then use paintable rockerguard and cover the with colour match base clear paint.
TwistedMinis   +1y
Por 15 goes directly on bare metal. It will peel off of anything else. Try it and stick some masking tape on it, you'll see what I mean.
You caught me seth! I didn't catch it till I posted
Severed701   +1y
whatever you end up putting on it..make sure it can withstand rocks and other road debris hitting it..otherwise you will end up getting a bunch of tiny "uppies" in the outside of your rollpan or skin
