am i right
am i right
MMLILJOKER
ok so im planing my 4 link it will be triangulated. do my upper bars have to be the same length as the lowers? i know that both upper and lower have to be parrel to the ground at ride hight. i just dont want any binding ill be using coil overs so its not reall adjustable. what pinion angle do i need to set it up at for ride hight. i herd 3 degrees but i wanna know for sure. whats the min bar length? its all custom so ill build it however i have to to get the best ride and handling. sorry for the long post thanks in advance.
slammeddime
I think you should take a look at the two sticky threads. There's a lot of great info there to be read that will probably answer some, if not all of your questions. In short, no, your uppers and lowers don't have to be the same length, no they don't have to be parallel to each other, and no 3 degrees for pinion angle isn't optimum for every single situation. Everyone's situation is different and therefore no one can tell you exactly what to set your pinion angle to unless we're there measuring it with you. There isn't a minimum bar length, but you obviously don't want to get too short of bars if you want to have a larger range of motion. Hope that helps some.
s10
last post by baha +1y
