radius arm relocation?SD Brackets
metaltoburn
I talked to jerid from sd a few times and he didn't seem too sure about how these brackets were supposed to mount because when you set em on the frame the holes dont line up the holes on the bottom of the bracket are in the right back and forth location but dont line up where they're drilled on the bracket right to left my question is where exactly are the brackets supposed to be mounted cuz I'm just gonna weld em on!
draggin88's avatar
draggin88
mine didn't line up either i had to slot the holes to get it to line up on the bottom.
bodydropped85's avatar
bodydropped85
cut the center bar out then line it up. if its a v6 it has to come out anyways.
mindlissmetalfab's avatar
mindlissmetalfab
The 94 I did worked OK. Just had to drill out a couple holes but the bar was fine.
We have another one in the shop now so I'll soon find out if this one works or not.
dan48p's avatar
dan48p
i had the bag on my v6 but it was touching the exhaust... oh yea, the holes didn't line up on mine either.
Fraynlame's avatar
Fraynlame
I had to cut the bar off mine. just clamp, line em up and weld em in.
kevin@aac
I had to cut mine also. The 4.0L have a larger exhaust. If I remember corectly my holes lined up fine.
