20'S DONT FIT ...WHERE DO I GO FROM HERE
B224U2NV
I KNOW I KNOW..I HAD A CUSTOM OFFSET MADE THEY WERE 8 INCH RIMS WITH A +34 OFFSET..i MEASUERD FROM BEDSIDE TO BEDSIDE I'M ABOUT HALF INCH TO AN INCH FROM CLEARING...i HAVE HERD I HAVE THE OPTION OF GETTING MY REAREND SHORTEND OR COURIOR REAREND AND A OLDER TOYOTA 4X4 REAR END..WHAT CAN I DO THATS NOT TO EXPENSIVE?
detached's avatar
detached
on your profile it says you have gio wheels i didnt know that they did custom offsets.
also are you running 2wd metal or 4wd metal... believe it or not it makes a small diffrence...
the older toyota 4x4 axels i believe are the same if not wider...
best bet would be courier rear or having the axel narrowed. theres a post on here in the mazda section about 20s and tucking its been a while but ill pull up the offsets needed...
detached's avatar
detached
will tell you now. An 8.5 with +40 or +42 (come on, seriously, 2 mm is like a 16th of an inch) will NEVER TUCK with drop spindles and 2wd sheetmetal. It will also BARELY tuck without drop spindles and with 2wd sheetmetal, and only in the front, the back will chew up fenders.
in order to know offset you have to know width. The two go hand in hand, as I'll explain. Without knowing width, you could run ito trouble just basing your wheel buying on offset alone. For example, IF (hypothetically, not having anything to do with mazdas or any specific truck) IF a 7 inch wide wheel with +20 barely tucked, an 8.5 inch wide wheel with +20 will stick out almost an inch. Same offset, different fit. Here is how to figure it:
Figuring backspace from offset and vice vera is EASY. You need to know width.
step one: add an inch to the width. A 7 inch wide wheel is actually 8 inches wide lip to lip because of the half inch bead on either side. adding an inch allows you to know the exact centerline.
step two: divide by two. This is the centerline of the wheel. Any offset quote is given FROM THIS IMAGINARY LINE. Thats what offset means, "the wheel mounting surface is OFFSET from the center by + or - XX mm. A + offset means the mounting surface is offset to the front side of the wheel (FWD cars are high + offset) a - offset means the mounting surface is offset to the inside of the rim (you have seen wheels that really stick out, thats - offset)
step three: convert the mm to inches. 25.4 mm = 1 inch, so divide your offset number by 25.4. If you want an easy way, go to google.com and type in "XX mm in inches" (where XX is your offset number) and it will convert for you.
step four: If it was + offset, add the offset in inches you got in step three to the wheel centerline measurement you got in step two. If it was negative offset, subtract the offset from the centerline. This is your backspace.
Recap: Add an inch to the stated width. Divide this number by two and record. Convert mm offset to inches. Add (or subtract) this number from half the width. = backspace.
SO lets use what we know: +42 on an 8.5 inch wide wheel.
8.5 + 1 = 9.5
9.5 / 2 = 4.75
42mm / 25.4 mm = 1.65
1.65 + 4.75 = 6.4 inches of backspace.
to go the other direction, converting backspace to offset, is easy too.
divide by two
sutract this result from the stated backspace
convert the result to mm by multiplying by 25.4mm
So, 6.4 backspace on 8.5
8.5 + 1 = 9.5
9.5 / 2 = 4.75
6.4 - 4.75 = 1.65
1.65 * 25.4 = 42mm offset.
Back to mazdas. No way will a +42 fit with 2wd sheetmetal unless you do as said and narrow the upper arm. It absolutely will not fit the back, ever, unless you shorten the axle or go to a courier rear. The guy who has them also neglected to mention he is running an RX7 rear end, which will camber in like the front. For 2wd sheetmetal, 7 inches of backspace on a 8.5 inch wide wheel would be
8.5 + 1 = 9.5
9.5 / 2 = 4.75
7- 4.75 = 2.25
2.25 * 25.4 = 57mm offset. Which is moot, because they dont make anything that high offset in 6 lug.
Switch to five lug. the toyota rear end will give you some extra tuck in the back, and you can buy 20x7 with +40 offset in a 5 on 4.5 pattern, which will tuck great on a maz.
Back to top
Russ-D
View other posts by this member. Posted - 2 June 2006 9:8
oh, and adding 4wd sheetemtal will give you about a 3/4 inch backspace cushion.
SO if you needed +39 on a 7.5 (I know this fits, I had it on a previous truck)
7.5 + 1 = 8.5
8.5 / 2 = 4.25
39mm / 25.4 = 1.54
4.25 + 1.54 = 5.79 or roughly 5.75 backspace
having 4wd sheetmetal will give you .75, so you need 5 inches of backspace to tuck a 7.5 wide wheel.
7.5 + 1 = 8.5
8.5 / 2 = 4.25
5 - 4.25 = .75
.75 * 25.4 = 19.04 or roughly 20mm offset for a 7.5 wide wheel.
To use this number to figure up what you would need on another width wheel, find the FRONT SPACE for the wheel you know fits. This frontspace CANT change and still tuck no matter the width. To find frontspace, you subtract the backspace from the total width.
7.5 + 1 = 8.5
8.5 - 5 = 3.5 fronspace
For an 8.5, you would need
8.5 + 1 = 9.5
9.5 - the frontspace you know fits 3.5 = 6 inches of backspace.
now figure out offset
9.5 / 2 = 4.75
6 - 4.75 is 1.25
we already know that 1.25 * 25.4 = 32mm offset.
So, knowing that a +39 7.5wide wheel fits with 2wd sheetmetal, we figured out what offset we needed to fit a7.5 inch wide wheel (20mm) and an 8.5 wide wheel (32mm)with 4wd sheetmetal.
dont thank me thank russ d hes the mazda god on here...
balcar's avatar
balcar
Courior/B2000 rear would probally be a little to narrow, but then u can allways run a spacer. 150 for a rear, 100-150 for drive shaft and 4-link or leaf spring perches and your done. Definatly the cheapest way that I know.
B224U2NV
I'm tuckin in the front right nowon a 2wd i'm about an inch away from layin out in the front.. the back i'm just tearing the tires up..as for the toyota 4x4 rear end i was told that if its before 84 it is a direct bolt up 6 lug like mazda an about 2 inches shorter.
B224U2NV
o and yea they dont do custom offsets..I had a guy order blanks and we drilled them out to fit mazda 6 lug and any gmc or chevy and suposedly newer fords..
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
wow too much math for me
BAGD RANGER's avatar
BAGD RANGER
uuuuuuuuuu ---- just get 18's ---
dssur's avatar
dssur
the camber is what is letting you tuck in the front, when the camber is gone, so is your ttucking.
In the rear you can use a courier rear end, it is about 3 inches narrower overall.
This could have been avoided by asking first, or searching. Offest and backspace needed for a mazda has been covered about 100000 times here and I still dont mind answering it over and over. THe last situation you want to be in is yours right now, where you have already laid out the money for the rims and need to spend more to make them fit.
B224U2NV
Fuck some 18's ..I found a courier rear end..if anyone wants the 20's i'm prob gonna sell them 4 some 22's i just got a hook on..
