Air Ride Suspensions \  I know the answer is Slams but...
Air Ride Suspensions Q & A
views 210
replies 16
following 11
scotto79   +1y
What size would be best on the front of a mazda b2200 with a v8? Should I go with Re6 or Re7's? Would the 1" lift between the 2 models make that much of a difference between running 18's or 20's on the front?It will be sfbd'ed eventually as well.
MIDWEST DRAGFEST   +1y
if u want to go with slams the Re7's is what i would suggest. i dont know how the slams are now but in a year i went through 8 slam bags. 5 front 3 rear.
mindlissmetalfab   +1y
Keep in mind you will probably have to notch the side of the framerail to have enough clearance to stuff an RE7 in the front of a mazda.
I would just run re6s.
holcombe347   +1y
if it were me i would put contitech 2500's (4-ply) up front. i love mine. absolutley no problems with them crackin, splitting, bubbling, etc. they have been on my truck for 2 years now with no problems and the truck is driven daily
scotto79   +1y
it jsut seems that everybody on here has suggested Slams at one time or another, then everyone responding here has a lot of different opinions. I really just plan on going up and down, don't need to be breaking my neck with speed or anything like that.
scotto79   +1y
If there are other companies that have a really good quality, let me know those as well please.
keele   +1y
Re6's are your best bet. Thats what i bought for the front of my hardbody when i had it. Re7's hit the spindle or I would have had to notch in my frame.
TwistedMinis   +1y
I channelled out my frame to put RE7s in front. It gets more lift, with less pressure. It should ride better up high where I need ti to turn, than an RE6 would have. It takes 90 PSI to get 10" lift. Before at 120 PSI I got about 8" of lift.
DRAGGINBODYON22S   +1y
RE7S WOULD BE YOUR BEST BET IMO
AVTekk   +1y
cut for 7s if you can man
