Air Ride Suspensions \  Who gets the most lift???????
Air Ride Suspensions Q & A
views 145
replies 7
following 7
Hc Daytona Dragger   +1y
Which Bag manufacture gets the most lift out of there bags? Slam, Contitech, Firestone etc.... is there a chart?????
I have Firestone 2500's now and I need a little more lift, help a brother out
FABLAB   +1y
In my experience installing Slams kill the competition in every way. They lift higher with the same (or even less) PSI, are more durrable and just look better. There is a chart on Slam specialties website http://www.slamspecialties.com/ open that and click compare. Hope this helps
scotto79   +1y
I've been looking into this as well, and Slams are winning in every aspect. None of the others keep the same diameter at all pressures like they do.
FABLAB   +1y
Yeah man that is the biggest thing, guys try to stuff a bag in a spot that might be just a bit too tight and end up rubbing a hole. The bag not expanding outward also is what transfers into more lift. For our application Slams are just the best. It would really be cool if they offered interchangable top and bottom plates to make it easy to use their bags on struts.
fyrexp2001   +1y
i had the slam rs 82s in the rear of my s10 over the axle and it got almost 13 inches out the bag. on 200 psi, i run conti's up front and slams out back
Thanx guys, I'll check into this.
FreelandKustomz   +1y
Aim bags
hahahahahaha
