Air Ride Suspensions \  c10 lower bag plate on front question
Air Ride Suspensions Q & A
views 398
replies 5
following 6
80chevyc10   +1y
was wondering if just using the suicide doors flat round plate in lower a arm will be a problem. the bag looks like it will rub on edge of a arm any advice
kevin@aac   +1y
build a higher cup, or modify the arm. The bag will fail in time if its rubbing. But you probably knew that.
DLYDRGR   +1y
I think IF Customs runs the bag in the lower control arm with no plate or cup. I think i saw this on the Matt Eye and/or chris' 67
BigPimp   +1y
i chopped the cup all the way down in mine. I have the plate on the upper part. The bag sits into the bottom A arm when layed out...
I run SS RE7s
cdndragrr   +1y
thats what i did i welded a round plate to my lower control arm because the bracket like ssd has didnt lay low enough for me
bluec10   +1y
i used the the kit from suicidedoors and firestone 2600 and it only rubs when its all the way down
