Ok I know someone has ask this befor but I cant find the answer. I have a 89 blazer (compact) that I bagged up front. I cut the spring cups on the frame. have 2 inch drop spindles and I still aint laying up front. I'm still about two inches before my tie rods even hit. what do I cut next. Thanks for the help. oh eah something else on my mind been reading a lot about people talking about minitruckin and the life style well My opion that is that I eat sleep drink to it and even day dream it.if some one had to call me anything(example prep punk wigger etc) it would be a minitrucker weither i had a minitruck or not I love it and it is my life along with my two little girl that will love trucks too. sorry had to get that out there
FreelandKustomz
is your bag compressed all the way???
dropedtrk13
yea I think so. well I far as I can see it looks like the lower control arm is the frame.not sure if anyhthing else is hitting.really I think I just answer my own qestion.
granth
if the bag is compressed fully....its not going anywhere else I wouldnt think....but if not, notch the frame for clearance of the control arms and get er on the ground.
rockstar-c10
There is a hump on the top of the lower control arm, see if that is hitting the frame, if it is cut the frame around the hump or notch and reinforce the arm then all that is left is notching out for the tie rod.That should lay it out.Also what size tires do you have?
detached
also what rim & tire size you running? did you remove the bump stops? what cups are you running?
MIDWEST DRAGFEST
like big e said about the cups they might be too tall and need to cut the cups down
doordraggintaco
cups too long?
kevin@aac
Post pics, its way easier. If we can see it.
mindlissmetalfab
Also notch out the lower control arm mounts to allow the arm to travel up higher.
What brand cups are you running?
Last but not least, how big of wheels and do you still have inner fenders.
