rockers and pinch on HB?
greybush
Edited: 2/6/2007 9:09:48 AM by onmyrockers
I'm trying to bd my HB and need to know the easiest way to get rid of the pinch molding and the slanted down part of the rocker so I can lay flat rocker.
DDlowztaco's avatar
DDlowztaco
Me and my buddies bodydropped a HB last summer and we bent them under the rocker. Because there is alot of strength you are loosing when you just cut them off. If you think about it all the weight of your cab will be resting on those rockers I would want them as strong as I could get them.
keele's avatar
keele
I made relief cuts in mine pinch about every 3 inches with a cut of wheel then rolled them under
baggedhb
i drug mine off, drove it and drug the hell out of it and it was fine....
McClarys's avatar
McClarys
just bend them up .. . you can use a heavy hammer and hammer little at a time all the way down , then do it again .. dont try to bend it all at once.....
N
nissanpimpin
drag them bitches off
deflatd
drag em off
I
inssan
you can either hammer them over or you can friction weld them off
stopndrop
