need new bushings for juice any thoughts?
bigern85023@yahoo.com's avatar
swchhpy's avatar
swchhpy
All of my bushings are shot on my Wagon, I need to replace them. i was wondering if anybody has used stock again or upgraded to poly? i have heard that the poly's make a lot of noise and r real stiff?? I have juice with big ass cylinders. what r ur thoughts???
olskoolpup
definately use poly. they arent squeaky if you install them with grease like you are supposed to. its not so much that the ride is stiffer, but the ploy doesnt absorb minor vibrations like rubber does. but seriously, its more like a "sport" ride, not like riding in a red wagon or anything.
juicedwagon
i know 2nd look(brian from aon) did a energy suspention kit on his. i will be doin a energy suspention kit on mine. well i already have it just got to put it in. have fun pushin all of the oem bushings out though. use lots of grease when you put the together and you'll be good
jeebus @ mmw's avatar
jeebus @ mmw
yep, just like everyone else said, aslong as you grease the poly bushings, they will be fine and not make a noise for ya.
swchhpy's avatar
swchhpy
thanx 4 da input. i think i found what i'm going to get on Ebay...
phatzz's avatar
phatzz
I always replace the bushinsg with energy suspension bushings, Its nice because you dont have to press them in, just make sure to use the grease they supply. I used them in all my hondas with no problems.
The front lower control arm shock bushing & rear lower control arm shock bushing usually tends to wear down fast when you got air or juice,.
s10
last post by baha +1y
