4 link installation
4 link installation
damnstarr
hey guys i just wanted to make sure that the best way to install a link is at ride hieght or is it just as easy when its layed out.
damnstarr
nobody?
Thebutchershop's avatar
Thebutchershop
layed out
johnz
i disagree but if you install it correctly the pinion angle shouldnt change from layed out to ride height but i always find it easier to do it at ride height weld some steel from the frame to the axle to hold it in place then pull the stock shit..and weld in your 4 link
AVTekk's avatar
AVTekk
ride height, you want the lower bars parallel to the ground.
mindlissmetalfab's avatar
mindlissmetalfab
Edited: 2/6/2007 6:54:58 PM by iLLblazer
ride height for sure. Thats where you want your geometry to be perfect since its where your truck will see the most wear and tear. I usually set up links with the axle up against the bottom of the stock frame since most guys roll fairly low.
Thebutchershop
guess im not as smart as i thought i was
