huskerdually
My wife got this email and forwarded it to me so. I don't doubt the actual science stated but I do doubt that it would make any difference in how much gas you get when you fill up.
I don't know what you guys are paying for gasoline....
> but here in California we are also paying higher, up
> to $3.50 per gallon. But my line of work is in
> petroleum for about 31 years now, so here are some
> tricks to get more of your money's worth for every
> gallon..
> Here at the Kinder Morgan Pipeline where I work in
> San Jose , CA we deliver about 4 million gallons in a
> 24-hour period thru the pipeline. One day is diesel
> the next day is jet fuel, and gasoline, regular and
> premium grades. We have 34-storage tanks
> here with a total capacity of 16,800,000 gallons.
> Only buy or fill up your car or truck in the early
> morning when the ground temperature is still cold.
> Remember that all service stations have their storage
> tanks buried below ground. The colder the ground the
> more dense the gasoline, when it gets warmer gasoline
> expands, so buying in the afternoon or in the
> evening....your gallon is not exactly a gallon. In the petroleum
> business, the specific gravity and the temperature of the gasoline,
> diesel and jet fuel, ethanol and other petroleum products plays an
> important role. A 1-degree rise in temperature is a big deal for this
> business. But the service stations do not have temperature compensation
> at the pumps.
> When you're filling up do not squeeze the trigger
> of the nozzle to a fast mode. If you look you will
> see that the trigger has three (3) stages: low,
> middle, and high. In slow mode you should be pumping
> on low speed, thereby minimizing the vapors that
> are created while you are pumping. All hoses at the
> pump have a vapor return. If you are pumping on the
> fast rate, some of the liquid that goes to your tank
> becomes vapor. Those vapors are being sucked up and
> back into the underground storage tank so you're
> getting less worth for your money.
> One of the most important tips is to fill up when your
> gas tank is HALF F ULL or HALF EMPTY. The reason for
> this is, the more gas you have in your tank the less
> air occupying its empty space. Gasoline evaporates
> faster than you can imagine. Gasoline storage tanks
> have an internal floating roof. This roof serves as
> zero clearance between the gas and the atmosphere, so
> it minimizes the evaporation. Unlike service stations,
> here where I work, every truck that we load is
> temperature compensated so that every gallon is
actually the exact amount. Another reminder, if there
is a gasoline truck pumping into the storage tanks
when you stop to buy gas, DO NOT fill up--most likely
the gasoline is being stirred up as the gas is being
delivered, and you might pick up some of the dirt that
normally settles on the bottom. Hope this will help
you get the most value for your money.
