lights
Y
lights
suksgas
whats the best way to smoked light lenses?
thanks later
lophat's avatar
lophat
Wet sand the lights down with 600 grit, then dry them, pre-clean and tack them.
Get some clear, add some black base paint to it...maybe a ratio of 4:1 (4 being being black). Mix it up with the recommended hardener/reducer and shoot. I generally eyeball the amount of black I add. Try it on a crappy tailight first and see how dark it gets after two coats.
I don't like the BLACK BLACK BLACK tailight look. Less is more I think with smoking lights. I generally try to get it to the desired darkness after three coats max. So test it out and if you need to, just add more black. Then I wet sand and buff the lights...they look like factory if you do them right.
P.S. I should clarify, mix the clear so its ready to spray BEFORE adding the black paint. So what I mean by the 4:1 ratio is clear with hardener and reducer added part black base right outa the can.
liljlowrider's avatar
liljlowrider
Yep exactly like he said....
jcampbell1180's avatar
jcampbell1180
Buy them a pack when their young.
huskerdually
I was going to say make sure they are dried good. Rolling them is the hard part, but nothing worth doing is easy.
lophat's avatar
lophat
You guys are too much.
pig rig's avatar
pig rig
I was thinking that also
also getting them lit is kinda hard but once you get them to burn its nonstop untill their gone
