Starter
joe_robles@cable.comcast.com's avatar
Starter
robles228's avatar
robles228
Can a bad starter drain your battery. I replaced the battery and the alternator.If I don't start my truck daily it won't start after sitting for two days. Any ideas?
robles228's avatar
robles228
anybody?
bowtied's avatar
bowtied
Start checkin your wiring! If you pull the battery cable off and touch it to the battery post and it sparks you got a short somewhere or somethings on that shouldn't be. If it's a big spark then that could be whats wrong. You might check the starter relay. And check to make sure there's no lights or anything on at all. GLove box lights tag lights underhood lights etc! Good luck. But it sounds like a wiring problem to me.
robles228's avatar
robles228
Thanks i apprecitate the info.
CHOSN1's avatar
CHOSN1
I'm sure its not your problem but I have noticed on my 97 tahoe that if I lock my doors and let it sit for a few days, it barely starts up but if I don't lock it, it works good after the same period of time. But i would go with the other answer and say it will be wiring
CHOSN1's avatar
CHOSN1
i just did a search on parasitic drain and i found that vehicles equipped with an ECM can exhibit a failure mode within the ECM which can result in a high parasitic drain on the battery
robles228's avatar
robles228
Someone told me it could be my ground.So i will start tracking in it down. thanks for the info.
