stock gauge swap 89-95 pickups
standardbyker88@yahoo.com's avatar
standardbyker88's avatar
standardbyker88
is there any stock gauge stuff that i can swap into a stocker 2wd 89-95? like with an in dash tach, oil pressure gauge, voltmeter/ammeter, gas gauge, speedometer, water temp...sorta thing. instead of like 3 gauges and a bunch of retard lights.
like i heard the SR5s had better gauges. will it plug and bolt right in? or do i have to splice? not a problem, but is something to consider. also, will it mess with the computer? thanks guys.
EC
eyecandy customs
it will plug right in, but u will have to change the oil sending unit sensor to make the oil guage work on the sr5/ 4runner guage cluster...............
standardbyker88
so the 90-95 4runners and 2WD/4WD SR5s all have the same 6 gauge cluster? and i can just get the new sending unit at like napa? sweet.
i looked, but does anybody have a picture of the cluster?
2lowtoy
89-91 cable drivin 92-94 electric driven speedo. Just have to swap oil pressure switch to one with guage on either style eazy swap
gtpunk18's avatar
gtpunk18
I have a 91 pickup and a 4-runner cluster and my spedo cable doesnt match up to the gauges there a different style
sitnlow4life's avatar
sitnlow4life
I was thinking of doing this swap as well
I have a 92 Pickup so as long as I get a guage cluster from either a 92-95 SR-5 Pickup or a 92-95 4-runner I should be fine?
standardbyker88
well, found a cluster and a new sending unit. got it all installed last night. all the gauges work, except the tach. even with it off, but the key on it reads 2500rpm. starting or driving doesnt change it. remove the key and back to zero it goes. i checked, its not stuck. thanks guys.
