Timing
mavverik@sbcglobal.net's avatar
Timing
TwistedMinis's avatar
TwistedMinis
Anyone know Toyota timing specs for a carbed motor? Like how many degrees advanced or retarded at TDC. I need to set it up close so I can test fire the motor and fine tune it and break it in. Right now I have it set at 0 degrees at TDC.
1lowfatkid's avatar
1lowfatkid
i see your using a MSD box so i dont know if this is will work but worth a shot
http://www.lcengineering.com/technotes/index.php?p=view&catid=1&id=54
twinkie0786
just leave it a zero or advance it alittle a move the distributer to change timing.
If that site doesnt tell you anything.
TwistedMinis
That site seems a little extreme. Someone told me 8 degrees retarded, now I'm not so sure.
cookiemonster13's avatar
cookiemonster13
seth to start go about 5 degrees past tdc. if you are running vaccuum advance and it is hooked up you should be at final mark about 10 degrees advance at idle and 15-20 at full throttle.
cookie
time1's avatar
time1
Hit up the Pirate4x4 site seth, there lots of tech about that stuff over there.
TwistedMinis
Cool, thanks guys.
