alright.....getting ready to order...
granth
What should I go with for epoxy primer...
Im lookin at either HOK KD2000, or something by dupont. I really want to go with HOK though. My next question is...where can I get rage gold? I want to either use that or evercoat for any filling that needs to be done.
What PRIMER should I use as well? Im guessing over bondo and all, I should use a polyester primer, but if I go HOK, which one? dupont?
I am spraying hot rod flatz for now as well, as I don't want anything "shiny" before final paint.
granth
also, if im spraying just my engine bay..is a quart of epoxy, a quart of top coat primer, and a quart of the color top coat enough?
TwistedMinis's avatar
TwistedMinis
A quart was enough to do my engien bay. I have half a quart of color left, or about. Almost used all the clear though. Did the dash and stuff too though.
granth
cool Seth. Im just looking to do the engine bay/core support. Looking to use that hotrod flatz, but have you seen/heard anyone talk about the metallic kind? Im kind of between that and normal because the color I want is the metallic kind, but the normal would be easier to patch incase I needed to.
KrazyFullsize's avatar
KrazyFullsize
Rage is a good lightweight body filler, i used to use it at the other bodyshop i worked at it was verry easy to sand and held up verry well, we aso use a filler calle Platinum filler. it is also a good filler. both are sold at PPG and sherwin williams paint stores i know and run about 30 bucks a gallon, the evercoat putty is about 20 bucks a quart and is also sold at most automotive paint stores...as of house of colors I cant be any help cause ive never sprayed them...
TwistedMinis
I heard its harder to spray without looking streaky. I bought a solid color.
granth
Edited: 2/18/2007 1:06:34 PM by framedragger
they just dont have the color i want they only have it in metallic....but thats really not the color i want if its metallic...
KEEF's avatar
KEEF
http://www.southernpolyurethanes.com/Photos/epoxy%20primer.jpg
Good shit right there and u can get a gallon which makes 2 gallons for what quart of DP cost, ive been using it for 6 yrs with absolutely no problems.
this is the full site addy with all products/info http://www.southernpolyurethanes.com/homepage.htm
granth
i know primer can absorb water and all that crap, but if we will be driving it this summer, would it be okay to just spray the epoxy for now? I really want to get started on the frame...
project94
i never like leaving anything in primer only for the fact it doesn't have any protection from moisture or uv's if anything i would just single stage it so you just have to come back and block the area when you're ready to paint
:fon:
