the best place for ranger arms
11 following
devilx000@peoplepc.com's avatar
devilx's avatar
devilx
i've read the forums and know that byc and their arms blow,so where can i get tube control arms without getting the djm ones?
st Ranger's avatar
st Ranger
Why don't you want the djm ones ? They work perfectly
TRUKBLDR's avatar
TRUKBLDR
there will be some new arms on the market possibly later on in the year but are in the R & D stage right now. I will keep you posted on their progress
bodydropped85's avatar
bodydropped85
stock will work just fine
devilx's avatar
devilx
i heard the djm ones break ball joints and how can i make the stock ones work?Zing the frame? how much does that cost normally cause the guy that does my welding is scared to do it.he says it's because that it is an 03 he doesn't want to take the chance of messing up a newer truck and i can't afford the down time cause it is my daily.
balcar's avatar
balcar
as apposed to screwing up a old truck? Doesn't sound like much of a welder...
BYC is no longer around, so nothing is needed there. I would Z it, but find someone who has more skills in welding.
ricky@3rdshift
You can Z the frame rails and use DJM's just fine to get down on big wheels.
Hell you can lay on at least 18's in front with just DJM's and a little trimming.
I would also replace your ball joints with Moogs. BTW where did you get the info on breaking ball joints. I know Ranger suspensions are bad about wearing them out quicker.
devilx's avatar
devilx
that's just what i heard.i want to play my options before jumping in to get them.my guy is a jam up welder,he just never attempted a mod like that just mild stuff like bagging and shaving.i'm not sure how long it will take.can it be done in a weekend?
ricky@3rdshift
Z will take more than a weekend.
devilx's avatar
devilx
so what do most shops charge? i'm not that far from mr.scrape.maybe they won't charge much
