Sanding
dbridges80@hotmail.com's avatar
Sanding
dannie's avatar
dannie
WHAT ARE THE RIGHT STEPS TO START SANDING DOWN MY TRUCK
jhoz's avatar
jhoz
how far down do you want to sand to. if you want it down to bare metal grind it off. it all depends on what yout trying to do!
granth
i wouldnt just GRIND it off...not with a big grinder anyways haha. They have stripping wheels made for doing just that, removing all paint. Sort of expensive, but does't thrash on your metal.
Severed701's avatar
Severed701
yeah you need to be a little more specific on what your trying to do
dannie's avatar
dannie
I WANT TO REPRIMER. .THE GUY DID A CRAPY JOB ON IT .SO I WANT TO DO IT RIGHT
slammedcivicsi's avatar
slammedcivicsi
if your going to re prime it, I'd just buzz it with your DA with some 240 or something.But you will have to primer over all the 240 scratches. If your spot priming then 320 the area around the primer.
-Brad
jhoz's avatar
jhoz
you have to worry about "mil" thickness, which is how much material is on the truck. the more material you have on the truck the more problems your going to have later on! i guess your could just scuff the primer with a red scotchbrite pad and lay a better coat of primer down if you dont want to spend the $ on sandpaper etc.
CadeCustoms's avatar
CadeCustoms
block the truck down with 150 grit, make sure its straight, then lay down a few coats of good primer. There are too many variables amd your not being very specific. do you give a shit how the bodywork looks??? what kind of paint job is it??? is it base clear, single stage??? u have to be a lil more specific, do you want it to come out right???? or are u just gonna rattlecan primer it????
shavedmax
paintucation.com
dannie's avatar
dannie
I DO GIVE A SHIT . I WANT IT TO BE RIGHT .NO RATTEL CAN. THATS WHAT IS ON IT NOW.IT LOOKS LIKE SOME ONE USED A GRINDER ON IT .SOME SPOTS ARE BAD .IT DID NOT GO INTO THE SHEET METAL.HOW DO I TAKE ALL THE PAINT OFF AND SHOULD I DO THAT .THIS IS NEW TO ME REALLY WANT TO LEARN
