Nissan hood options
Nissan hood options
RHMNISSAN
Does anyone know of a way to keep the stock nissan HB hood with a bodydrop. And if not, any one got any good ideas on how to do the hood as far as a cowl or bubble?
deflatd
you can drop the motor some or mess with the air cleaner assembly. i have an older style flat hood with eclipse bubble and shved vents if u want
baggedhb
anything up to 3" just have to take the plastic top off the filter and get rid of the studs holding it down, the hood will hold your filter on just fine, held mine for over a year....3.5" you may have to trim some hood supports....anything more then, and dont want a hole in your hood you have to get creative....my trucks bd'd 6" with a completely stock hood, didnt even cut hood supports. well not for the motor anyhow, cut them for the wheels.
deflatd
^ air filter depends on motor. it was a bit harder with my z24 vs a ka
Iownissan's avatar
Iownissan
i had a 3.5" body drop with the ka24e, just had to take off the plastic air filter crap and use only the air filter itself, and trim down the two studs that hold the filter down.
msturg's avatar
msturg
my buddy is doored with a stock hood. custom intake and a lowered motor.
tenfrontier's avatar
tenfrontier
You could always swap the intake manifold with one from a 240sx.
deflatd
is mine on my z24. clears with a 3" bd
danshoods
one option is a showdowncustoms.com cowl hood check it out
baggedhb
i lowered my motor, and had to take a small section out of the right side of the oil pan to clear the frame and a 240 intake manifold
