one side sits higher than the other?
dro3303@netzero.com's avatar
LowXpectations91's avatar
LowXpectations91
ok i jus lowered my 91 s10 with 3" in the front and 4" in the rear.... i put NEW 2" Drop Spindles up front and NEW 1" drop coils and jus New 4" blocks in the rear.... everything is NEW... nothing was heated to where anything would be warped of any such....does anyone kno why it sits lower on the left side than the right... and its mostly in the front you can tell!
olskoolpup
thats the dreaded chevy lean. every s-10 i know of does that. the only way to compensate is to put a 1" spacer on the drivers side, or cut the passesnger coil little by little until it sits even.
its something GM did at the factory. has nothing to do with what you lowering it, or the gas tank (as some may say), its just how the control arms are.
olskoolpup
oh, belltech makes a 1" coil spacer BTW. its a polyurethane cup that sits between the coil and the cup. i remember minitruckin having a tech article a couple years back about it.
KaoticSonoma
gotta love that s10 lean....happens on all gens......like bryan said pick up a 1" spacer that sits on top of the coil spring...that should fix it.
LowXpectations91
does anybody kno the exact link to where i can get that spacer? ...thanx everybody
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
my c10 does that(85 longbed)the passenger side is like an inch or so lower, is it the same problem?
KaoticSonoma
i think i ordered mine off of stylinconcepts.com...but you should be able to get it anywhere that sells lowering kits
dodgeman's avatar
dodgeman
i had the same problem with my dakota havin the gangsta lean still have it actually guess its my fat azz sitting in the drivers seat,lol.
BggdNBdyDrppdJunk
im gonna just call it a day and say my truck is in its "ready stance"
s10
last post by baha +1y
