Hey guys. I have a late model F-150 with the 4.6. Also I have a built 351 Windsor and aod trans. Am I thinking correctly that the swap would be easier than going the other way, Carb to EFI. I know I will lose the speedo because that is electronic off of the trans, and the fuel tank wont be an issue. The real question I have is the wiring. Would the same wiring work for like the starting circuit etc. Just trying to get some info before doing this.
bodydropped85
it would be easier to get a new harness.ie painless etc. you will have to change the column out for an older one or a ididit style one since it has the PATS system in it. the factory wires wont work cuz its thinkin the efi motor and pcm is stillt here.
