pressure switch and relays
jlchampion74@hotmail.com's avatar
jrock74's avatar
jrock74
what are the advantages/disadvantages for running a relay for your pressure switch.had airride for less than a year and i'm on my third pressure switch.no relay.why does this keep happening?do i really need a relay
whynotfab's avatar
whynotfab
The pressure switch isn't made to handle the constant amps the compressor draws. You use the relay to act as a switch between your battery and compressor, and your pressure switch triggers it.. allowing the flow/kicking compressor on. Relays are cheap, and definitely needed. What compressor(s) are you running?
jrock74's avatar
jrock74
viair 450
whynotfab's avatar
whynotfab
for just that compressor, a 30-40 amp regular bosche style relay is fine.
jrock74's avatar
jrock74
thanks.i'll look in to that
jrock74's avatar
jrock74
what's the best way to splice the relay into my wiring?where is the best place to put it?wish i would've put it in when we installed the airride.
