need help
need help
beloved
i just got a b/d ranger as a project and when i air up the front the motor moves before the cab does is this normal or not ive never had a b/d truck before thanks a lot for the help
incognito 1's avatar
incognito 1
PLEASE REPEAT ? I DONT UNDERSTAND. ARE YOUR CAB MOUNTS I.E RUBBER SPACERS SQUISHING TILL THEY BOTTOM OUT THEN THE CAB LIFTS??
MF
Master Fabber
It should not do that. The weight of your cab is on the mounts all the time. Sounds like something is flexing big time.
tuckin eh's avatar
tuckin eh
maybe it's got too much of a bodydrop. as in you might need to space up the cab mounts. sounds like it's laying on the body literally pulling or stretching your cab mounts. never heard of thsi problem before but it's my only educated guess. and if that is the case I'd get it fixed asap.
bodydropped85's avatar
bodydropped85
sounds to me like your frame is about to break in half.
beloved
what matt is saying sounds like the most reasonable awnser. when i air it out when the cab hits the floor i can still air the frame out about an inch or so. i dont think my frame is going to break because the frame is not cut into at all ill look when i get home and mybe post a couple of pics thanks guys
scotto79
how much is the b/d? it does sound like the rockers might be hitting the ground before the frame does. If your frame doesn't get damaged, your bodymounts probably will. Thats just my guess though.
beloved
from what the guy told me the body drop is like 5.5 inches ill have to get pic tonite
dan48p's avatar
dan48p
just cut the bottom of the body off until its even w/ the frame. or drag it off lol
bodydropped85
wow 5.5 is WAAAAY over kill no more then a 4 in is need, and thats still 1/2 to much. the body drop coulld be not welded very good, something is flexing REALLY bad.
