yota clip'd steering?
dan48p@netscape.net's avatar
dan48p's avatar
dan48p
what kind of steering columns and joints are you body dropped guys useing with your toyota frame clips? would a tilt column out of a exploder work with some special joint on the end to hook up to the steering box? this is for a 92 ranger but i imagine it doesn't make a wholle lot of difference, it would just be nice to beable to utilize some junkyard parts to tie everything together without having to spend an arm and a leg on a hot rod column.
bodydropped85's avatar
bodydropped85
stock column, w/ the stock yota joint and anthoer joint comin out the stock column w/ a steerin shaft in it. you can use juck yar shafts, 150s and aerostars have 1 oe 2 univerals in there steering shafts, but you do need the one from the yota box so itll work.
dan48p's avatar
dan48p
are there any places that i can get an aftermarket joint that fits the yota box?
i don't believe that i have the stock joint from the yota steering. i might but i have to dig through a few scrap barrels.
maybe a joint that bolts up between the two and allows me to use j/y column?
