need some pics
tuckinlugs05@yahoo.com's avatar
need some pics
tuckinlugs06's avatar
tuckinlugs06
need some pics of how to move your clutch master cylinder
dragontoy22r's avatar
dragontoy22r
Of how? Just unbolt it from the firewall and remove the inner pedal linkage. Drop your truck till it lays and put the master cylinder remotely in the same area where the tire doesn't hit it. Cut a new hole and run the linkage through, then you can find the location for remounting the inner part. In most cases I'm aware of, you'll have to cut the flat bar connecting the foot pedal to the linkage and extend in the direction you want it. I've heard it coming to close to the brake pedal.
tuckinlugs06
ya to late i moved it lastnight and i just moved it to inside the firewall now the brake booster is next
