Air Ride Suspensions \  side/side
side/side
Air Ride Suspensions Q & A
views 144
replies 8
following 7
BggdNBdyDrppdJunk   +1y
i have front/back and pancake, what do i need to add to get my longbed to lean? (with airbags, not the way it does anyway...)
balcar   +1y
enough valves to give you independent control, either 2 or 4 depending on the valves. I guess thats what your asking. LOL
i have 2 in front and 2 in back, can i wire those to each work a bag?
TRUKBLDR   +1y
NO YOU NEED 8 VALVES TOTAL FOR TRUE SIDE TO SIDE THAT IS 1 FILL & 1 DUMP PER WHEEL INDEPENDENT CONTROL
clenzer72   +1y
8 valves total. a pump and a dump for each bag.
hows your roll over now when cornering??? i'm sure the air transfer makes it horrible, it will be a thousand times better with all four corners.
ok, thanks for the help guys
Minty Fresh Maz   +1y
Nah Bud, gonna need two for each corner.
Someone cool on hear will throw up a FBSS wiring/plumbing diagram, but im not that cool! Good Luck.
!!!HITTIN THREES!!! DFDub
balcar   +1y
2 for each corner on your standard 2 way valves. 1 on each corner for crappy 4-5 way valves.
fatboysS1O   +1y
there are plumbing diagrams on fbimini.com. id post it up but for some reason their damn website wont let me look at the pic. so try fbimini.com and see if itll let you look at it.
