Page 1 of 3
Ford Trucks \  notching Drop beam for passenger side?
Ford Trucks Make Specific
views 604
replies 24
following 10
metaltoburn   +1y
The passenger side beam hits the 4.0 oil pan before it even touches the frame so I notched it but I almost need to cut all the way through it to get clearance for it to lay what did you guys do?What size rims are you running? I was just gonna reinforce the beam almost like a c notch with some mitered tubing or something..
tbmx86   +1y
Section the oil pan or make damn sure you reinforce your beam well enough. Your whole truck pivots off of those beams.
metaltoburn   +1y
has anybody else had this problem? Ok if I section the oilpan can that in anyway effect the performance of the motor as far sumping the oil properly etc. never sectioned a pan b4
metaltoburn   +1y
aight well i just crawled out from under the truck the oil pan is fukn huge so I dont think it'll hurt to take some away its also cast so I don't know if thats gonna weld very well or not I can only hope I dont have to buy a new one!
bodydropped85   +1y
if ur tryin to do 20s, move the motor up unless your b/d then yota clip it.
menace   +1y
what other solutions are there for this? im going to be baggin my 92' 4.0L soon and i need to find out what to do... I'm only runnin like 17" at the biggest.
kevin@aac   +1y
I never had that problem. What beams are you running and what size rims?
metaltoburn   +1y
stockers and djm beams
pewter2000   +1y
i had a 91 b/d on 18s and i sectioned the oilpan w a piece of 2" pipe left the djm beams alone,worked great
metaltoburn   +1y
I know if i get the stockers to lay I can roll 18's.....you know at this stage in the game the more and more I do I wish i would have built an entire frame w/toy clip etc and b/d all at the same time because you pretty much dive into the truck just as much just bagging it
