Body work and Paint \  fiberglassing a door??
Body work and Paint Q & A
views 202
replies 6
following 5
CHOSN1   +1y
so when i put my door panel back on i will have 2 holes (one from door handle and other from window crank) and I was wanting to know how easy it was just to fiberglass over the door minus the door panel. Do you bolt a piece of plywood up to it or what?
CHOSN1   +1y
anyone
dakotamike   +1y
really wouldnt recomend glassing over the metal door it moves to much and it would crack try making a mold to mount on the door or glass over the actual door panel and keep your factory mounting spots
LOWEST1   +1y
There are allot of ways to do it. From scatch it is really easy to start with 1/4" mesonite or mdf. I usually fill the factory door panel holes. Dont know if that helps?
jdauer02   +1y
check out fiberglassforums.com and search. all the fiberglass info you need.
CHOSN1   +1y
thank you.. i'm finding alot of good stuff on that forum
KEEF   +1y
Also u need it to be removable to work on windows/door poppers etc Ken
