pinion angle on 2 link
peterbilt@suddenlink.net's avatar
80chevyc10's avatar
80chevyc10
was wondering how to set pinion angle and also maybe some pics i have a angle finder just need help. also fixin to z frame what is the typical z 3" 3 1/2" 4" ive seen all of these but what is best thanks
Low_SST's avatar
Low_SST
you need to pick a ride height and set it at that height, its gonna be fucked everywhere else in the travel tho.
91 drggn dime's avatar
91 drggn dime
2 links arent the best of setup, but they do work for their purpose. all the guys back home run them, on their feature trucks that are dailied and no problems. in town, you can ride anywhere and wont have any problems, its when you hit the highway, you want to be at your pre-set ride height.
you needed to get your pinion before you tore it apart.. then bolted the blocks and 2 link to the rear.. set it where you wanna roll it, stick your angle finder on it, then how ever many degrees you're off from your factory pinion, you shim it to meet.
s10
last post by baha +1y
