BodyDragginGMC
I just got a new daily driver (98 S10) and the heat stays on. The blower control works fine as well as the control that turns on the ac and directs where to blow the air. The problem is the knob that turns the air from heat to cool (blue to red). I am trying to see if there is a common problem with the blend door actuator or the control switch itself. I am hoping it's the control switch but at the same time I don't want to waste a bunch of money replacing the climate control if it doesn't fix the problem. I've searched and searched but the only vehicle I can find that has a common problem with the blend door is Fords. I can't even find a part number or anything at all on GM Blend door actuators. Anyone else had this problem?
