First rendering
First rendering
odog87 avatar
odog87
This is my first marker rendering, it is a modified 1997 ford expedition. I usualy do 3d graphics, and for the first time in my life I am in a position to fix my truck up the way I want it. I'm looking for comments and suggestions.
purplekush avatar
purplekush
looks funky
DougyFrisch avatar
DougyFrisch
looks like a 4 door el camino/mustang............. kinda
granth avatar
granth
i kind of like it, but you can make things look good with a pen. none of that will fit anywhere near as good as in the drawing, and look decent. you go much wider on the mustang, it looks like a retarded kid punched in the face, same with taller.
odog87 avatar
odog87
You are probably correct, but I still want to try, If it doesn't work then I will go with the new navigator front end. (I want to see if it can be done)
A straight bolt on won't work but they may be able to blend it in and stretch the front end out to fit
ShakinPlates avatar
ShakinPlates
intresting concept. good visual display
MysteriousGT1 avatar
MysteriousGT1
not bad, but im sure it would look kind of funky in real life...unless its fabricated just right!
