LC Engineering header
W
watatoy
I was wondering witch LC Engineering header to get. I have a 1994 toyota pickup with the 22re. Its going to be body droped to the rockers. I was wondering witch header would work the best for clearence issues if you guys could help that would be great.
truck action's avatar
truck action
I may be wrong, but think there's only one for the 22RE from LC. I have a 88 w/ LC 's pro street EFI, & their header, it hangs below the frame by a 1/4" to 1/2". Doug Thorley's sits higher , but say's it will not fit w/ a 5 speed ??
W
watatoy
they have one 22r/re formula toy header kit it says it four like rock crowlers for clearence. It says it dosent bolt up to the stock pipe in stufe but as long as it bolts up to the engine couldnt i just run the rest my self it says you could also buy the o2 sensor part to .
truck action
If you look at that header,it angles straight down, not back under the truck. Also states that won't work with a stock frame!
time1's avatar
time1
I put a LC header on my old truck and only used the header. They sent me an extra piece that is supposed to go before the cat that holds the O2 sensor. If i would have used the second piece it would have hung down below the frame. With just the header on i made my own pipes from there back. I even dropped my motor almost an inch to keep it under the hood for the BD and the header still doesnt hit the ground.
taco2nv's avatar
taco2nv
Downey-offroad makes a good header aswell thats what i have, for my taco.
TOYZRUS
Yeah i have ran a Downey for 10 years but i will get a jet hott coated from LCE next they are sweet....plus i don't have ground clearance issues...LOL
