Nissan Trucks \  HARDBODY LOAD SENSOR
Nissan Trucks Make Specific
views 181
replies 7
LndRanger86   +1y
MY HARD BODY HAS GOT A LOAD SENSOR ON THE REAR END. HOW HAVE YOU GUYS DONE AWAY WITH IT OR RELOCATED IT? ALS O I WANT TO KEEP MY CHARCOAL CANISTER SO WHATS SOMETHING CREATIVE WITH IT?THANKS IN ADVANCE
Bagged87c10   +1y
load sensor? u mean the spring loaded proportioning valve for the brakes? i just relocated mine and took off the spring...and i 86'd the charcoal box....
LndRanger86   +1y
the valves is what i'm talking about but where did you move it to?i'm doing a my bags straight behind the axle with the uppers welded to a bar from the backside,not the center(over axle ) like most setups. also what do you mean about the canister?thanks for the help
LndRanger86   +1y
bump...............
tenfrontier   +1y
You can remove the (lsv) load sensing valve and cap off the return line. If you really want to keep the charcoal canister you can relocate it forward of the axle. You can also eliminate the charcoal canister and put a breather on your fuel tank.
LndRanger86   +1y
I'M NOT A MECHANIC BUT ALL YOU HAVE TO DO IS PUT A BREATHER ON IT? WHAT DO YOU DO WITH ALL THAT STUFF? AND ALSO YOU JUST CAP IT AND REROUTE IT? SOUNS PRETTY CUT AND DRY. THANKS
ScrapinChevy00   +1y
boy i wish i would have know about the capping off the return line thing, cause i redid my whole rear brake lines and dont have abs on the back anymore and it kinda sucks, i got one line coming from the valve on the fire wall back to the rearend and then Ts off to both sides of the axle
LndRanger86   +1y
thanks for this too. i'm researching it more
